I wouldn't waste your time replacing the damper assy, very unlikey the cause. The picture is a bit blurry, a faulty head will typically have some nozzle deflection, especially in the vertical lines between the two color patterns, I do not see any. And the fact that you are missing a few magenta nozzles as well, suggests you are having a weak pump cap or maybe it could be very dirty as well as the face of the print head. You could let the head move over to the right and uplug the printer and clean the pump cap area and take a damp
paper towel, fold it flat and lay it in the path and move the head over to clean the face of the head...I really think you have a bad pump cap though. Those just went up to $464 from epson. Let me know if you want to give it a try, I can get you one. it is only going to help the overall health of the printer if you ultimately have to replace the head. One way to tell if the pump cap is healthy is to run a cleaning and see if there is fresh ink in the waste ink tank after....you can always put a bit of dry
paper towel in the ink holder to see if it gets ink on it
