Help with mimaki cjv150 not printing
budlinch
Totally confused on this one. I printed an rgb sample and noticed some lines running through the print. Did a print test and some of the magenta was missing. I did a thorough cleaning of the machine, replaced the cap assembly and the cp pad assembly. Did some hard cleanings and it started to come back, but not all. I then soaked the head for one hour. Went back after the hour and tried to do another test print but now I cannot get anything to print. The machine was printing fine the day before. Any help would be appreciated.
budlinch
Sorry about that SJ. That makes sense. I have put them in order. The last pic you can notice a small black line and that is all that printed.
Smoke_Jaguar
Lots of deflection, might be head starvation. Cap is a good place to start, decently cheap part. I'd do dampers next if they're old. Also check your wiper and do a nozzle wash. Hard cleanings are mostly just good at consuming lots of ink.
WizardWorks
still cheaper to pump a few hard cleans worth of ink through than it is to throw parts at it. I'd hammer 10-15 hard clean cycles through it before spending any money. I've recovered my print head from a nasty crash that way. took an hour of my time but worth every minute on the amount of cash i didnt have to spend.
Smoke_Jaguar
If nozzles are coming back during the cleanings, good to work with that progress. But if the head is losing prime, good shot at bad dampers or something else being the issue. Typical procedure I run people through is a series of normal cleans and log progress along the way. If things start getting worse, then parts are recommended based on what's happening.
Looking at a nozzle check can tell you a lot, can spot delamination issues like cross-channel contamination. Signs of air in the head, ink starvation, etc. Lots of people get into trouble when they just do a bit of searching and they just hope the simplest/cheapest thing would work for them. Seen instances of people changing multiple capping stations or even replacing lines when the issue was something as simple as a cartridge valve.
I'm not the type to just throw heads at stuff unless I know that's actually the issue. Dampers, caps and such are sub $10 parts if you order in advance and buy from your favorite overseas vendors. Even if you go OEM, still way cheaper than a $2500 head.
