help with set up
rtfavors
We have a sp300 roland printer and we are printing decals then cutiing them on a mimaki cutter, how does the cutter know where to start, will it read the register marks that are produced by roland?
rtf
rtfavors
the roland will not cut the way we want so we are printing on roland and cutting on mimaki through illustrator
cgsigns_jamie
Welcome from Florida!!
You will need to print the Mimaki's crop marks on the Roland. The easiest way to do this is to use a program like Flexi, there was a thread about this (cutting Mimaki prints on a Roland) the other day, use the search button you'll find it.
Also your Mimaki cutter will need an ARMS or similar registration mark sensor in order for this to work accurately. The alternative is to find the crop marks manually, and that's not very accurate.
Ken
Welcome from BC.
I'd like to know what problems you are having with the sp300 in cutting?
If you are print/cutting small decals..don't expect to run off 4 or more feet at once. Do it in batches or the contour cut will run off as you progess through the footage.
Also I recommend you allow the printer to cool (pause) before your cut operation.
Not always the best option, but you will get better cutting performance when the vinyl is not hot.
Cheers!
Ken
