Help with vinyl machine worth!
RC Woodworks
Hello to all!!! Sorry for the long post, but I need help!!!! I am wanting to expand my sign business with vinyl, banners, T-shirts etc. I currently make hand routed redwood signs and due to health reason have expanded to CNC. I have a Shopbot 4896 and a K2 CNC 2514 and a couple toy Compucarves! My site is www.rcwoodworksonline.com
I recently bidded on E-bay on a mobile shop that is nicely set up. The problem is the size of the shop. It is a 28 ft. motor home converted into a sign shop. The deal was 30K and included was a Roland PC 60 and a 30" Graphtec 4100. It also has a Shark CNC this included a few rolls of vinyl and heat presses for T-shirts. Plus computers and flexi sign pro.
I live in Ca. and I was going to fly to Ky to buy this unit, but I had second thoughts. Like I said the shop itself is too big for what I do. I go to county fairs and make my signs on the spot. So I thought including vinyl would be cool! Yet my mobile shop is 15' long and a 28' shop is too big.
Another reason for second thoughts I have checked prices for these machines and it seems the value is more in the vehicle not the equipment.
What I need is help could you tell what the value of a Roland PC 60 and a Graphtec 4100 and how old are these machines? Then what would be good machines to buy? My research found that these are good brand names. Please give me you advice for Roland, Graphtec or let me know of a good reliable machine.
Also do you think this shop is a good deal? You can find it on e-bay, I found it searching for Shark CNC machines or mobile shop. I really think the seller is pricing the unit and equipment, based on what he paid for it a few years ago? I understand, but values go down no matter the use.
Thanks in advance and I hope I didn't offend anyone with this long post and my ignorance!
Rick
chopper
the graphtec must be a few years old, but a new one goes for a little under 3k, the shark cnc I think would be some were between 3k-4k, depending on which model it is, the pc60 isnt worth much they had a lot of head problems
and are basically a POS, you can find info on the graphtec at the link for sign warehouse at the bottom of the page, as for the shark google shark cnc,
the whole deal seems to be over priced to me, and sign warehouse will also have the software,
new cargo trailer-5k-8k
new cutter (graphtec)-3k
shark cnc-3.5k
software- 2k
seems to me you could set up new for a lot less, unless the shark thing is alot more than I think 17k vs 30k you do the math
oh buy the way education at signs 101 - priceless //chopper
OldPaint
i got a mobile sign shop sitting....8 mpg is too much @$3.40 a gal.
RC Woodworks
Thank so much on the machine info! I know you can get a Shark from Rockler for $2295.00. But I wasn't sure about the vinyl equipment and I had a hunch they were not worth too much. The vehicle is a Blue Bird 1990 28' motor home that was never sold waiting to be customized. It has 148k miles on a Cummins with an Allison trans. It seems I would be spending more money on the motor home which I don't need!
I have a 08 32' class A Fleetwood Terra so I don't need a useless unit! I am thinking of another trailer, but mine is still very useful.
Chopper and anyone else what machines do you reccomend? I looking for a machine to make banners, maybe T-shirts, magnets signs and of course vinyl lettering and signs. As I said I have a Shopbot 48" by 96" CNC and a K2 CNC 25" by 14" and the software I have is Corel X3 and V Carve Pro, Photo V Carve and BobCad V22. So I will need to know what software is good and won't break my bank! Maybe something I could use for my CNC as well as the vinyl cutter.
Do I need a plotter along with the cutter? Please don't laugh I am new !!! I look forward for your help! PS I wish it was $3.40 a gallon here! It is $3.80 in Northern Ca.!
Rick
chopper
Rick
it depends on what you want to accomplish, the graphtec's are a good machine, I use a summa, there are others techman was talking about apd which stands for advanced plotting devices which was formally allen datagraph which was viewed to be the best in it's time, there is also roland, I would recomend that you start out with a cutter, which is the same a a plotter, the pc 60 is a form of digital printing, you will need to resurch this a little more to find a machine that will fit your needs.
the summa digital printer is similar to the pc 60 in that it is a thermal resin printer, the most common type of printer used today is the inkjet.
there are many types of inkjets any many brands,
some are for vinyl, some are for paper, or poster material etc, some will only print on coated material, etc, then there is the need for lamination, most outdoor printing will require lamination to make the print last outdoors,
some say that the thermal resin type dosent require lamination but in reality if it's going to be out side it needs to be laminated,
also there will be a learning curve, in running the plotter, printer and laminator, but since you are into the cnc you may have a good grip on this already, what you need to do is read a lot of the posts here and at other sites, and then make an educated decision for your self, I see that you are familiar with corel that will work to run your plotter also you will need a program like cocut pro to apply cutting paths, maybe some one who uses that will be able to help you better it is not the software I use so I do not want to mislead you there, do some research and asks some more questions you will be able to make the right choice, if you get a cutter you will be able to make t-shirts buy cutting your designs in thermal flex or some other heat transfer material and applying it with a heat press, the best rule of thumb is stay away from the chinese equipment, good luck //chopper
RC Woodworks
Thanks Chopper that is why I joined this forum to learn! I turned down the mobile shop deal yesterday because I have been researching the machines. I see you don't care for the Roland PC 60 and the Graphtec 4100 130 you haven't heard of! So that tells me it must be old!
In the mobile shop description the owner stated 20K in sign making equipment. That is what alerted me I know about the Shark and due to the construction of it I passed on it. But the cost is under $2300.00 My K2 CNC cost me $3600.00 and the ShopBot 10K! So I don't think the owner is trying to rip off anybody, but I think he is giving the price he paid for it! Like the computers that come with the machines, they become outdated quick!
Not to say anything is wrong with the machines, but I have learned here and from research I am better off buying new machines!!!
I would like for other opinions from the sign makers in here too. What I want to do is enhance my business by being able to make banners, magnetic signs, vanity license plates, custom vinyl signs and window lettering. Plus the software best for the job. I would like to be able to use the same software for my CNC and the vinyl machine.
Thanks in advance and to those who have replied!
Rick
