Help
Martinc5
Hi all, I am trying to install a HP L360 into Onyx 12 and need the PrnInst file for onyx 12 if anybody has a copy.
Thank you
jwlllpl
Martinc5
Unfortunately Onyx have stopped supporting Version 12 so drivers only available for Version 18 and up
jwlllpl
Maybe try contacting HP directly since their website is still linking for versions 11 and above. They may be able to help you get the older version.
Martinc5
Thanks, worth a try
jwlllpl
Where is the prnInst actually located? Is it on the disk or is it downloaded when you install the specific printer?
I believe it downloads and you install the printer. I have not used Onyx in years but pretty sure that is when you have access to it.
Martinc5
Ok, sorry then, I've got nothing.
I think the only way I will be able to get this is from somebody who is running onyx 12 and has the same printer HP L360 as the prninst file will be installed on the pc they use. Alternative is I pay for an upgrade
