Click to Support Signs101 ...
Hey guys how would I print double strike on the HP Flatbed 700, I am using Caldera RIP software on Linux. Is there a setting on Caldera for double strike or on the printer itself. Thank You!
Everytime I select clear Sheet when I load my media it won't change it to max dpi, it changes it back to indoor setting. Also on the RIP it tells me that i cannot use max dpi when mixing white ink with lighter inks.
Not possible to do a double strike on the FB700. Photo max dpi is the closest option. Make sure you have your resolution set to 1200x600. If it's defaulting back to Indoor signage you have our dpi set at 600x600. You may also need to build a profile for max dpi at 1200x600 if you don't already have one. Hope that helps.
