CENTERVILLE SIGNS
PLEASE ... THANK YOU ! ! !
I want to soak the ink heads so they don't dry upWhy are you trying to unlock the carriage? The printer not turning on isn't connected to that
I'm waiting for the main board, but I don't want the ink to dry upHi,
If your Roland SP-300 won't turn on, the print carriage will stay locked because it needs power to unlock. First, make sure the power cable is plugged in properly and try a different power outlet. Also, check the main power switch and fuse if you can. Don't force the carriage to move by hand, as it could damage the printer. If it still won't power on, the problem is likely with the power supply or another internal part, so it may need professional repair.
OK, if you are soaking the heads you don't want to do it for more than 24 hours, then after this you need the printer to do a self clean to clear the heads out. A better option when you can't do this is rather than soaking the heads to leave the carriage docked and turn the pump mnanually, this does the same as the normal self clean. If you turn the pump for about 2 or 3 minutes a couple of times a day.I want to soak the ink heads so they don't dry up
