How to Improve the Working Efficiency of Diamond Saw Blades
wanlongstone
Diamond saw blades are a type of processing tool used in industrial activities. They are very sharp and wear-resistant, with a long service life, and are therefore widely used. When using diamond saw blades, we all hope to improve their working efficiency. Below, we will explain how to improve the working efficiency of diamond saw blades.
The working efficiency of a diamond saw blade is related to the bonding strength of the diamond, and the diamond grit size and concentration used in the blade head. The higher the diamond concentration used in the saw blade, the greater the average density of diamonds on the working surface of the saw blade, the higher the wear resistance of the saw blade, and the longer its service life.
The greater the longitudinal density of diamonds in the working layer of the diamond saw blade, the more diamond layers there are in the working layer, and the longer the service life of the saw blade. The longitudinal density of diamonds in the working layer of the saw blade is related to the diamond grit size and concentration selected for the blade. The higher the diamond concentration, the greater the longitudinal density of diamonds in the working layer of the saw blade, and the more diamond layers there are in the saw blade; the finer the diamond particles selected for the saw blade, the more diamond layers there are in the saw blade, and the higher the wear resistance of the saw blade.
Diamond saw blades inevitably become dull after prolonged use. Another reason is that the saw blade itself may not be sharp enough. If a diamond saw blade becomes dull, it can be sharpened appropriately, but it should not be sharpened arbitrarily. Special sharpening tools should be used, or the manufacturer should be contacted for advice.
It's inevitable that diamond saw blades will become dull after prolonged use, but choosing a saw blade with good sharpness can delay the dulling process.
