How to install laminated window perf vinyl on the storefront?
phototec
Is it better to install laminated window perf vinyl on a storefront, wet or dry application?
Stacey K
I like making signs
DRY!!!!!! DO NO APPLY WET!!!!
Window perf is easy to apply if it's laminated. Many of us on here enjoy applying window perf. If you apply it wet the moisture will never dry out, you will have an absolute mess. The other thing to keep in mind is that after you apply it you are going to see squeegee streaks - no fear, as the vinyl sets the streaks will go away and the surface will be nice and smooth.
Reactions: 7 users
phototec
Ok, the window perf is laminated, with Oracal 290F, do you use application tape to apply or go without application tape? Thanks
phototec
Stacey, the window perf is laminated, with Oracal 290F, do you use application tape to apply or go without application tape? Thanks
gnubler
Good to know. I noticed that on a recent install.
Perforated vinyl is so easy to install even I can handle it without much stress.
Reactions: 3 users
Johnny Best
THe reason you do not apply wet is the fact the liquid gets into perf holes. DRY apply it is easy to do.
Reactions: 2 users
SightLine
No application tape is needed either. Unless its some contour cut multiple piece thing which is very uncommon for perf but oddly we are actually doing some of that very thing right now... and using 3M 8170-P40 super expensive perf.
Reactions: 3 users
Stacey K
I like making signs
Everyone above is correct. No tape needed :) - unless it's some weird shapes in that case see above
BetaCtz
What's the group consensus on paneling perf?
Slight overlap from panel to panel, or butted and then "edge taped" on a seam?
Original poster - don't forget to use edge tape around the perimiter of your graphic (clear or black cast 1/2" pinline tape).
This will make your install last much longer. Perf films tend to not last as long as regular films.
tulsagraphics
A bit of both. Overlap during install, but then cut through the middle of the overlap.. removing the excess from both pieces... which gives you a tight butt seam. Seal all edges and seams like normal.
Reactions: 1 users
Boudica
Tex, you didn't push it into the edges and trim it... looks like you had some trimming to do at the bottom.
Texas_Signmaker
Very Active Signmaker
  • First Place
Reactions: 1 users
Stacey K
I like making signs
I just received mine today! I'm so excited to use it, it seems very well made also
gnubler
Let me know if you like it. I bought mine based on Tex's recommendation but have never gotten the hang of it so I'm back to regular squeegees.
