How to install Oracal 751 matte black vinyl without lots of tiny bubbles?
phototec
I tried using RapidTac Application fluid, spraying it on a clean vehicle surface; however, I still get lots of small bubbles.
What is the right amount to spray on the vehicle surface, a light mist or more liquid?
I'm not sure if I used too much or too little. Any pro tips will be appreciated.
Is there a way to get rid of the small bubbles?
White Haus
Not a Newbie
You could try to poke/squeeze/heat but no guarantee you'll get them all out. Could also leave it out in the sun for a bit and see if they dissipate.
Personally, If I'm doing anything wet, I make sure it's soaking wet. Spray the vehicle, spray the vinyl, hell spray yourself a bit if you want to smell like vanilla. Then I use a fresh teflon squeegee and go to town. Start with a medium pass to get the bulk of the liquid out then just giver until you're sweating and your arms are burning. Think you're done? Give it another spray and another hard pass with the squeegee. Once you're done that, peel the premask and check your work. If you see any bubbles left, spray the vinyl with Rapid Tac and with quick/light passes (again, fresh sharp teflon squeegee) get those bubbles to an edge asap before the whole thing sets up.
That's my technique anyways.
  • Agree
  • I Appreciate You
Reactions: 4 users
GaSouthpaw
Excellent points, all. I'd also add practice, practice, and more practice.
unclebun
Agree that if doing a wet application it needs to be absolutely soaked. A fine mist will just make it worse, and you can't slide and reposition with only a mist anyway.
On that particular graphic, I don't think I would have applied it wet. It's best to learn on flat signs before doing installations on vehicles but cut graphics like that can be applied dry without bubbles.
  • Agree
Reactions: 1 user
bob
Work on your squeegee technique and learn to apply this sort of vinyl dry. The squeegee technique starts with the adage "Never, ever, let the squeegee completely leave un-squeegeed vinyl. Assuming you're right handed and you're going down and up, right to left. Start your stroke with the squeegee COMPLETELY on the previous stroke and angle it such that the stroke ends up with approximately 1/2" of the right side still on the previous stroke. How do you do the first stroke you cry? Very carefully says I, and start completely off the vinyl if you can swing it. If not then underline 'carefully'. The rest of it is practice, lots of practice.
  • I Appreciate You
Reactions: 1 user
Grizzly
It’s all about your print!
Also, make sure you're pushing hard enough the first time you squeegee. Too light of a squeegee and then pushing harder after it's all down will cause these types of bubbles.
  • Agree
Reactions: 1 user
incrediblesignco
for wet applications you need to be sure you have a good balance of soap to water mixture - alot of water is not going to help if it evaproates before you can apply it. also depends on the temperature of the environment. but my rule of thumb is baby shampoo, a couple drops in a large mister. test the spray on glass, you want to see just the faintest of soap bubbles, and you're good to go. espesialy on a painted vehicle, that water get's pushed out quickly and you're stuck with bubbles. reach out if you want B
ps that vinyl is a wet application vinyl. it is not air release so on a vehicle with contours it needs liquid. it's from the 80's, the time before air release! but nice and permanent. I have striped ferraris with that stuff
Gary1
Could also be how you're pulling off the premask. With wet application, if you pull the premask straight up, you are puling the vinyl off the vehicle causing air pockets
to form. If you're using a dishsoap and water solution, you maybe putting too much soap causing lifting of the vinyl to occur when the premask tape is removed. A couple drops of Dawn or Joy dish wash soap in a common spray bottle
should be fine.
I do not use any soaps or application fluids. I'll sometimes spray down premask tape with water to make the premask remove easier.
Sometimes a roller does a better job, a new squeegee really helps too. Check the edge and sharpen if need be. Pay attention to the angle of the strokes
and overlaps and down force as well. And proper preperation of the substrate is critical. Give the vinyl a little time to set up before removing premask especially when doing wet application.
One can only give proper advice when one can actually observe and see how it is actually being done. Many variables can take place resulting in different results.
Gary1
And NEVER wet apply reflective vinyl unless you're using Rapid Tac II. Maybe other solutions work, but I've only used Rapid Tac II on something where
I really needed too.
TEN
Hard squeegee pressure. Make sure you don't miss any areas. You can't go easy then come back harder, the bubbles will already be there. Also - You can wet mount it or use a matte black with air release.
