Hp 800w printing Cast Clear Vinyl
Kiwipips
Hi All. We have an issue when printing cast clear vinyl on our 800w where the vinyl lifts and gets stuck on the top of the curing unit. Polymeric clear is fine, it is only cast.
Doesn’t happen when it is actually printing, it will be in either the preheating or curing process that it hits.
Once it hits the vinyl stops moving forward, curls over the platen and eventually the headbox will come out and jam on it.
Any ideas on how to avoid this issue.? Thanks
There are several options to avoid media crashes or ink smears on the 700/ 800 Series, but they all share one common idea: to increase the forward tension on the media, without wasting front edge media. One option, ideal for short 1-off jobs is to use the Media Feed Accessory that should have shipped with the printer (the weighted blanket).
Another approach is to use a media strap as demonstrated in this training video:
  • Informative
Reactions: 1 user
balstestrat
Problem Solver
If it's non-paper backer your root cause is likely that it gets stuck to the bottom on the hot steel.
What you then need is to always use take-up-reel and the curing blanket pretty much solves it.
1upgraphics55
Use the edge holders, which will keep the media flat in the printing zone. We've also made it standard practice to ALWAYS attach ANY media to the take up during the loading process, as well as calibrating the take-up on each load. Even thicker materials (after experiencing the same issue with 13 oz. banner) will get too warm and cause a carriage strike during pre-print warm up and post-print cool down. :p
