HP Basic Plus 54" Cutter Jagged Edges
Neu2Signs
What would be causing these jagged edges? They seem to be more pronounced near the end of the run. I am using the perf-cut contour.
Does this occur when using a kiss cut rather than a perforated cut?
Perf cutting can de-stabilize the media sheet unless the perf/ flex cut settings are well dialed-in to the media, and even then, perforated cuts are much faster and cleaner when cutting on axis orthogonal line segments than curves.
  • Agree
Reactions: 1 user
Neu2Signs
I don't think it does, it just started happening with the perf-cut.
