HP Cutter54 Mainboard Question. Need to inform machine it is a 54 inch/ not 64 inch
Salagra
We had issues with our mainboard on our HP 54 cutter, so it was replaced today. This plotter is made by Summa so maybe a solution for our issue will work for each. The board that was replaced is for a 54/64 HP cutter. When we power it up, all initial diagnostics work, but the machine is reading it as a 64 and a 54. It tries to find the pinch rollers and comes up with an error that it can't locate them and to turn the power off. I was told it is a firmware thing, but I cannot find where to change it on the machine or through HP cutter control panel. I am wondering if it could also be a jumper on the board itself or something. Any help would be greatly appreciated.
Thanks,
Tom
Salagra
I tried holding down Up Arrow and Enter key when powering on to access the service menu, but I can't seem to get into it. Am I using the right key combo?
FrankW
You can also boot up Summa/HP Cutter Control while pressing Shift-Key to enter service mode of the software. Then you will find additional buttons and you will be able to set machine type.
Salagra
Thanks for the help. Was able to change it in the cutter control. It changed the model number, but we are still getting a "Pinch Roller Not Found Error, Turn Power Off" message. I guess I will have to make another post for this error now.
