HP Designjet 8000s Media Misaligned with 3m Dusted material
AKwrapguy
Having an issue loading a role of 3M Dusted material into my HP Designjet 8000s. When I load the media, it is unable to find it giving me a message that the media is misaligned and needs to be reloaded. I think that this might be due to the transparency of the material and backing.
Does anyone know of any workarounds or way to defeat the sensors?
iSignDesigncom
Theres two hiles on the front heater and middle under rollers. I put tape there to cover. It worked. But recently after about a year. Has stopped working.
tbullo
Superunknown
Covering the holes may work. I have done this before with a piece of 1''x 8'' long transfer tape on the edge so it would detect it when the head moved over it. Then it would work fine.
Motoko Susu
when we use the solvent clear iron-on transfer material on our 8000s we also place the blue painters tape over the eyes it fakes out the printer by blocking out the light.
AKwrapguy
We just did a huge project with this. So there is a sensor on the back of the carriage that you will need to 'fool' I just used 1" masking tape and ran it about 18" or so on the bottom of the material and it worked fine.
