dauod
hi,
I need your help to solve the problem in my printer
printer model: HP designjet L65500 (lx600)
Problem Description:
Front spindle does not respond when I trying to move it, but when i make a substrate load its moving, but Moving slowly
Some attempts and the results:
I am confused now, and I can not locate the problem.
I ask you to help me please
thank you
- Swap the the front and rear motor cable.
- When I measured the voltage that outside from the front spindle socket located on the printmech I do not find any value, knowing that I press to move the spindle on the front panel button.
- I did some tests in the list of diagnostics menu but all of them do not show any error in any board
- i make a some test for spindles from diagnostics menu the spindles moving, But they do not move at normal speed, but the test result (ok).
thank you
