Unit continues to stop in the middle of printing and displays the 23:10 error code. I'll list my trouble-shooting steps at the end, but suffice it to say that I've read all the posts here and elsewhere, and tried everything short of replacing the APS pumps (I can't devote any more time to this).
My problem now is figuring out how to get it serviced. This machine is in a public high school. I normally take care of the maintenance myself. I filed a ticket with HP Customer Support and it is just getting ignored. We buy a lot of supplies from Grimco and they mention a maintenance plan? I'll take any and all suggestions. Cheers!
Troubleshooting steps:
Run air pump system test in diagnostic mode. System pressurizes to 5psi, holds pressure and depressurizes no problem. Turned off machine while pressurized and listened for leaks. Replaced all print heads. Reseated all ink cartridges. Tapped on APS cylinders in case there was a stuck valve. Unit will start printing and before throwing the 23:10 error. As far as I can tell, everything is printing well except for the Cyan, which looks streaky despite having a brand new print head. I do see air bubbles in some of the ink/optimizer lines. Someone in this thread said to run with one cartridge removed each time (to see if the problem is a faulty cartridge), but if I try to print it just tells me to insert the missing cartridge.
