Hp latex 360 different colors on long prints
Dimepigrafes
I printed with my Hp latex 360 12 files of 155mx350m that each of them joints one another (self adhesive vinyl). On 2-3 joints, the colors were different, like they printed with a different colour profile. Every file was exported with the same colour output (Cmyk, iso coated v2) and printed with the same profile on the printer (12Passes, 90 Ink Density). All printheads work fine and im working the genuine latex ink cartridges 775 ml HP 831.
Dimepigrafes
OP-OP 836ml
LM-LC 1551ml
C-K 719ml
C-K 619ml
Y-M 1029ml
Y-M 1020ml
If i rotated what would changed? My joints are in the 3,50M side. And if thats true, do i really need to do this every time? Im new on latex, i also have a roland rs 640 and i havent had any problem like this!
balstestrat
Problem Solver
I would say replace that LMLC just to be sure but can't say much more about the numbers. Still pretty low.
Yes, as you rotate you will match the same side of the printer when you install. It can have a noticeable effect. Old latex has more change than newer ones but you could apply the same setting with solvent as well.
jon vital
One of the downsides of Latex
There's a thread on here from a guy who bought 560's and they were effectively unusable for the wall wrap work he was doing
Dimepigrafes
To be honest in comparison with my roland i always have problems. I also have huge difference in dimensions, even on small prints. For example, i printed several files (100,5 cm x 100,5cm) and i've got 100,5cm x 96cm.I also had problems with the colours, they always seemed not so vivid, but at least i found a profile that i liked. The ink consumption seems to be at some times 3x times bigger than roland, even though i try to use profiles with less ink density and passes but without luck. Τaking as a given that the cost of the ink for me is 2 to 3 times more than the eco solvent, i cant find any way to have it work on my business . Im really desperate, i cant find any advantage really in comparison with my old Roland. If someone agree's or disagree's i would like your opinion on this.
balstestrat
Problem Solver
I think you just need to get someone who knows how to run it to visit you.
Im also curious how you would compare the consumption as it's not very easy to get realistic values from both.
Dimepigrafes
Yeah that would be one solution , even though its difficult to find someone in my area. For the consumption, i have some estimated values after i print the file on latex and i just rip on roland and get the estimated ink consumption on versaworks. Another thing that i forgot and absolutely hate, is the loading of the substrates. On Roland is so easy and straight forward, i don need to sacrifice a lots of material in the start of the print, the whole thing is fast and easy but on the other hand the latex seems to me so complicated, get many times the material stuck or crumpled inside till i manage to pull it out.
balstestrat
Problem Solver
Yeah but that's the thing it's not comparable in reality. Roland will calculate the expectation of it, could be close too so that's not necessarily the issue. But HP will use the "real" calculated value afterwards and include previous cleanings to it as well.
Surely you will also dump the Rolands waste ink every so often but it's not visible in the calculations. Anyway that's just one thing and there's more to it like HP needs the maintenance cartridge which is an added cost.
