HP Latex 360- Does anyone know what the optimizer test plot is supposed to look like?
Goooost
It's pretty clear what all the other printhead test plots are supposed to look like, but I cant find any information about what the optimizer printhead test plot is supposed to look like. Should it be completely black or should I see lines? IMG_0470.jpeg IMG_0469.jpeg
I'm having an issue with solid colors doing this thing on the leading edge and all the print head test plots seem normal but I could never figure out what Im looking for in the optimizer so I've been suspicious of it. IMG_0480.jpeg
Steenland
Old Member
I don't have the answer to your problem, but I may have a workaround that could help you make some prints while you're trying to figure out the real answer.
I used to have this problem on my Z6100 and I never did figure it out. My workaround was to run a bar of a similar color, an inch or two thick and as wide as the art, in front of the actual art. That way, the banding happened in the bar, and was gone by the time it started printing the actual art.
Of course, you'll have to gang the color bar with the art so it prints as part of the same job, just in front of the art.
cornholio
Op should look just like the other channels, just with a black background.
When you have problems at the start only, run color stripes at the sides whenever possible. How much ml usage are on the heads? Could also be worn heads.
Goooost
I ran a color stripe and it worked, thanks for that idea.
Not sure how to check. I typically have only seen this kind of banding on oranges/yellows so maybe I need to change yellow/magenta 6- the magenta has like 25 little gaps in the pattern, mostly at the bottom so I didnt really notice. the other magenta on printhead 5 only has 1 gap
EDIT-
Nvm that was the old plot before I ran a cleaning, the new plot only shows one gap. Maybe that's all it needed and not the color bar. However do you see how weird the arrows and the grays look in the diagram? is that any indication of a problem or does it just not use optimizer in those areas?
Steenland
Old Member
The mottling you see in the arrows is typical on the test print. My test prints look the same. (I have a 365.)
Here's how I view printhead usage on my 365. Your 360 may be a little different. From the main screen, select the Inks menu, then select the Printheads submenu. From there you can select individual printheads to see detailed info on each, including how much ink has been fired.
Goooost
Okay so the amounts are as follows:
1: OP-OP 561ml (installed 5/17/26) in warranty
2: LM-LC 4398ml (installed 4/6/25) out of warranty
3: C-K 7255ml (installed 6/2/25) out of warranty
4: C-K 1085ml (installed 6/17/26) out of warranty
5: Y-M 2804ml (installed 5/4/25) out of warranty
6: Y-M 920ml (installed 5/14/26) in warranty
So maybe #4 was expired by the time it was replaced if it matters and 2,3, and 5 have been used a lot. Is there a good rule of thumb as to when its time to replace them?
balstestrat
Problem Solver
Over 5000ml and any issues arise just replace it straight away. Lmlc even less than that.
Bonzai901
I believe you can't see Optimizer plot print but I think if you do a Force Drop it tells you about how many nozzles each printhead is missing, also I dont remember tho code for the Force Drop is a four code number
Goooost
Hey so I'm replacing the super old ones and is it normal for the LMLC printhead to need to be "broken in" out of the box? Because they barely hit any of the targets on the test plot but after many cleaning cycles and just printing some big bands of those colors, the LC does the full plot and the LM does most of it (I'm still working on breaking this one in).
I did shake them before inserting but the box says to just shake them 6x, I didnt do much more than that. Perhaps I should have.
If you are experiencing a significant number of nozzle outs with any HP Latex printhead, you can attempt a manual cleaning if the printer cleanings are not effective. Here is the procedure (pics are included):
1. Take a non-shedding paper towel and fold it repeatedly to create a multi-ply pillow.
2. completely dampen the paper towel with water (ideally distilled water), do not use mineral water containing total dissolved solids.
3. Set the printhead with the nozzle plate down on the damp towel for about 3 minutes. Do not rub, simply allow the water to contact the nozzle plate. After 3 minutes, lift the printhead from the cloth and look at the cloth. You want to see lots of ink on the cloth. If one channel has lots of ink and the other side has less, put the printhead back on the cloth in a clean area and repeat.
4. When both sides are showing significant ink on the towel, gently wipe the nozzle plate long ways using a clean area of the damp towel.
5. Replace the printhead into the carriage, and allow the printer to check the head for continuity and nozzle performance. The printer will then initiate an automatic PH alignment.
It is important not to repeatedly rub the nozzle plate on the cloth, we are relying on capillary action of the water to rewet any dried ink in the nozzle orifices.
  • I Appreciate You
Goooost
I think I might just be getting some cross contamination on one of the Yellow Magenta Printheads because I am still getting some of these issues in greens and oranges, and a few of the test plots I've printed have had a bit of magenta in Yellow 6. But it isn't all the time. I think that's what's eluding me.
cornholio
When you have cross contamination in just one MY head, replace it. Also look at the maintenance cartridge for irregularities. I once had a case, where the spit roller didn't turn and ink built up until it touched the heads.
Goooost
Good advice. it has a pretty distinct sound when it turns I think and I hear it. It's a new cartridge anyway but good to know that's something that can go bad.
