Eveyone's feedback here has been great! Just a quick background on myself. I have been in the printing industry since 2010, so not too long, and have run Mutoh and
Roland Eco-Sol Machines, Agfa Anapurna Flatbeds, CNC machines, Summa and Graphtech Cutters. I have had a decent amount of experience with Latex printers as well and prior to my purchase of the 365 I have operated the L26500, L28500, L360, LX600, LX850. I honestly don't recall this many head strikes on any of the other models. I will have to place a call with HP to have them come out and see what is up. They have already been here stating it was a common problem and they disassembled the front of the print and cleaned the impinging model, which didn't look all that clogged or dirty to me. They also installed a Pressure Sensor. The tech stated that the pressure sensor was installed on the 360 models but not on the 365s for some reason?
I do use the heat blanket but with regret. I always get warping of the material right down the middle of my prints caused from where the mats meet in the center. I wonder if they make one continuous blanket with no seams? Seems to me, they should have created the head guard as one mat to begin with as opposed to the two sections.
I'M NOT A FAN OF THE TAKE UP REEL. I do use it when I absolutely have to. I like the leader idea that would certainly help things. I have used wrap magnets to give the material a little weight as opposed to setting up the take up reel. It helps as well.
I also have issues when I try to automatically load substrates. They get caught on the platen lip right in the center of the machine where the feed rollers are. So I have given up on the load technique and manual load.
On certain prints that I do, that have a lot of dark saturated colors, I also see vertical banding which I would only describe as inconsistent curing. It's not hard edge banding per say but it looks as if there are 5-6 4" section across the heater that do not cure the ink. I had HP look at that and run test all to say the heaters are fine.
I fully understand that profiles are basically created in clean science labs with perfect scenarios, but when you take a base profile for a 15oz Smooth Banner and run it as suggested at 210 degrees and it head crashes and you take the heat down to 172 what do you do? The material I am referring to now is Key Banner 15oz Block out. I downloaded the profile from Grimco's site and just finally got it to run well using the heat mats but I I can stand how I get the ripple in the center of my prints as I described above. It's like there is a fix, but not a 100% good fix.
I have a hard time accepting all these tweaks, adjustments and the monkeying around you have to do with this machine, considering the overall amount of money that is spent on the machine, rip software, setup etc. I feel these things could have been tested further prior to releasing these printers. Instead of coming up with practical fixes they simply launch a new machine (500 series).
I mean sure they make bullet proof materials that work beautifully but the fact of the matter is you have to spend anywhere from $.80-$1.25 psf for those materials. I don't know about everyone else on here, but my client base does not want to pay anymore for their projects that are currently printed on material that are in the $.16-$.38 psf cost range.
I'm just frustrated all. Thanks for your feedback everyone and keep on trucking!
