HP Latex 570
C_support
I purchased a used 570 about a year ago and am still trying to make it work. It is running fine now. The initial issue was error 79:04, which appeared to be a problem on the HP server. They forced me to get on-site service and later issued an official message to the customers that this error is connected to the server connectivity problem. Downgrading the printer firmware resolved the issue.
Currently, I have 3 issues that I would like to fix.
Issue #1. Intermediate tanks are not refilling automatically. I have an HP 370, and the intermediate cartridges are refilled during the print process. On 570 The level drops very close to the locked zone - 0.6 L, and I click on "Force refill" do not run lower. The manual says that they must be refilled automatically when the level drops below 82%. From this point, it should be 0.64 L. Not happening to my printer. Are there any settings that need to be adjusted?
Issue #2. When I attach printed media to the take-up, it is walking to the side so the media bubbles in the printing area and the printhead strikes the surface. No matter how I attach it or what I do, eventually it will hit... Are there any adjustments?
Issue #3. The intermediate OP cartridge is not recharging. It looks like the pump is dead. Where to buy a replacement?
Any ideas?
ToTo
Professional Support
#1 Ink will be refilled at about 66%, this does not cause any issues
#2 maybe the input rollmodule isn’t lining up with advance roller. Measure distance from empty core to cutline on both sides and adjust roll module position accordingly. Verify that bushing of diverter roller are not worn out. Check also advance roller for debris and sticker.
3# N2G70-67028 3 liter optimizer ink line, or disassemble the pump head and clean the rubber flaps and reinstall them upside down.
C_support
Thank you! What is included in the N2G70-67028 ink line? The line itself and the pump? Can I buy the pump separately?
ToTo
N2G70-67028 contains the quick connector, pump and tube up to the intermediate tank. K4T88-67026 is the pump only.
C_support
Recently, I pressed the "force refill" and the optimizer cartridge magically refilled. But in reality, nothing went into the intermediate tank. A couple of days late, the printer stopped with the message that the intermediate tank is out of ink. I took the optimizer intermediate from my HP370 to finish the job. But when I was removing the cartridge on the next day to return it to 370, the cartridge was puffed like too much air was pumped inside. I see it with this printer only with the optimizer. What could be wrong? Will the pump replacement resolve the issue, or should something else be replaced?
