victor bogdanov
duplicate
The cost of of quality polymeric calendared (54-inch x 50 yard) vinyl roll is roughly $200, this is close to $.30 per square foot - with many costing more than this. Even the least expensive economy grade monomeric vinyl is difficult to find at $.15 per square foot ($101 for a 54-inch x 50 yard roll), and it will likely shrink and fail in short order with outdoor exposure.duplicate
Wouldn't UV be more desirable for the higher value applications?Second, there are a many higher value applications that print & mount cannot compete effectively with direct print, including printing to acrylic, glass, brushed metallic surfaces, high-end wood for interior, and more.
Finally, cost justification for lower volume rigid printers is simple and straightforward - and it doesn't take anywhere near thousands of boards to get there.
Another way to look at it is it's like having another employee. You can load a 4x8 sheet in walk away doing other stuff while it's printing.. it's slow enough that you can print a board and go load printers / laminators / graphtecs while it's printingSo let's say you save 15 cents/sq ft on vinyl printing direct and a few dollars in mounting labor per 4x8 ft board .
This hp printer is 90k, so you'll have to print a couple hundred thousand square feet of rigid before you come out ahead vs doing on roll2roll.
Again this is keeping in mind that this printer is for " low volume" rigid.
High volume I 100% agree need a true flatbed or good hybrid but for low volume this doesn't make much sense
Yea but it takes under a minute to mount a 4x8 on flatbed table. Again if you're doing a sheet here and there idk how much time you're saving and if you are doing more then there are probably better flatbeds available in this price rangeAnother way to look at it is it's like having another employee. You can load a 4x8 sheet in walk away doing other stuff while it's printing.. it's slow enough that you can print a board and go load printers / laminators / graphtecs while it's printing![]()
Like I said before it's nothing like FB but really it's the successor of it as the low-mid range machine. R1/2 has good registration and I expect this to have the same. Automatic vacuum zones as well and real vacuum pump (3) while FB just had some fans.I started with an fb500 though, and I hate belt / hybrid printing. Registration is much, much harder and it was never bang on for us.... The suction is nowhere near as good as a true flatbed... (Maybe you can turn off zones on this new printer?) or maybe it has a better registration system.
Would be interesting to know the sales of the r1/r2, see if it met hps expectations.... Or if the sales were bad so they came out with this model trying to compete.
Then again that flatbed is sitting doing nothing if you happen to have no board(job)s to print and no roll option. Problem with that is also the ink you have chosen to use. There's always a trade off.Yea but it takes under a minute to mount a 4x8 on flatbed table. Again if you're doing a sheet here and there idk how much time you're saving and if you are doing more then there are probably better flatbeds available in this price range
It's basically L800 inside. Small heads, maintenance cartridge (not separate roll) and yes it does have intermediate tanks.Is this the small format R2R printhead architecture? Looks like no cleaning station or intermediate tanks for ink delivery.
The R530 is shipping now. Check with your reseller on delivery window timing.Has anyone pulled the trigger on one of these yet? Have heard they aren't shipping until August? We are seriously looking at it to replace a broken 360 and get the 4k out of it.
And how is that? I don't think you have even seen this new one let alone used it.FB500/700 was way more automated
It has automatic position and width detection. Usually when they run shows they just print chosen things with simple setup and won't do anything else.Balstestrat is correct is correct I haven't personally used the machine, but saw it demonstrated at last weeks Fespa show in Berlin.
I could be wrong, among other things, it looked like it lacked the camera/placement function which I find is a great feature on the old Scitex FB's
it's could also be the demonstrator not being quite up to snuff on all it's features - In general it looked kind of cheap, which it only is compared to the Big Brother Latex flatbeds..
And that is coming from a guy who has loves his latex' since gen 1 and currently running 3 x 570 in production.
Too expensive for the small shops currently running roll to roll and too cheap for the big buys running semi industrial UV, as I see the world right now.
Okay thanks. Yes, our supplier said August if we ordered now. Sorry, my message was unclear on that.Yeah it's already being delivered, already having my hands on one. Maybe if you order now it might take a month or two.
I would say expect similar performance. You still need heat and if the substrate is heat sensitive.... It's going to deform.Okay thanks. Yes, our supplier said August if we ordered now. Sorry, my message was unclear on that.
Do you know if it will have the same issues as the bigger R1000/2000 with thinner substrates and the heat causing warpage? Also with the double sided 1st surface getting damaged during 2 surface printing? From the R1000 thread it looks more like profile settings can alleviate the latter?
We are scheduling a demo soon and hopefully will be able to address these issues directly but wondering if anyone has hands-on on this machine yet.
Their inks or machine?FB500/700 was way more automated and industrial than this new overpriced plastic toy!
If only I had been able to fit a never generation printhead on our old FB500 I would have kept it... in the end Print quality / speed was the only thing that killed ours, could be solved with never gen heads.
Personally I would keep my eye on: https://www.hongsam.cn/
I am currently testing their ink, but different formula because of different printheads. Their printer is pretty much standard Chinese. Epson I3200 printheads, Hoson controller etc.Their inks or machine?
