HP Scitex FB700 Light Cyan and Light Magenta Not Working anymore ??
Selena
Hi,
Light cyan and light magenta heads are not in operation , they were working fine then all of a sudden they aren't ? It did say vacuum Pressure too low and I did adjustment but it didn't help ?? Switched to STS Inks Any help would be appreciated. Thank you
greysquirrel
Make sure ink is printing the filter on the ink box and getting to pump. Hold paper towel on filter and actuate while squeezing the bag. You should see ink. If you go verify pumps are working when initial mixing a purge. If that checks out then check orings vetwrmeen upper and lower reservoirs
