Huge banners
THATgirl
Between 7.00 and 8.00 a sq. foot is what I usually charge. Or you can price by the lineal foot adjusting for the width. I have 3 prices for each size also.
Basic Banner
One color with outline or simple logo
More colors/drop shadow/ complex logo
gtjet
We usually use sf pricing on banners but choose to either print or cut based on the actual project as opposed to being locked in one way or the other. Also we indicate that the sf price quoted is a base price and that depending on the exact job prices may be higher. We always try to up sell by offering about 3 choices per project although this is more true on vehicle graphics and store signage. A plain, simple one, a nicer one and a eye catcher. Sometimes it is a challenge and sometimes the customer is very firm about what the want so that is exactly what we do, it all varies a lot.
bob
I too decide to print or cut depending on just how the portents might align that day. Mostly I print, assuming the image is in reasonable proportion to the banner.
In these parts I do square foot pricing as the basis for pricing on most everything. But it's not a linear rate. In other words you don't just multiply height*width*rate. I use an exponential curve, a base ft^2 rate below which I will not function, and a maximum ft^2 rate that I would charge for a 1 ft^2 specimen.
The ft^2 price for any item is calculated as:
base rate+(max rate - base rate)/ft^2.
This yields a nice exponential curve that starts at the maximum rate and becomes asymptotic about the base rate. In other words, the bigger it is the less the ft^2 price is but never going below the base rate. The nice thing about doing it on the curve is that you don't end up charging either too little for small stuff or too much for big stuff as you do with a flat ft^2 and the curve tracks the time expenditure pretty well thus giving additional validation to the method.
I used to figure vinyl as a separate material by the linear foot used off the roll. That was always clumsy to me so I incorporated the typical vinyl usage into the base and max rates. I have three sets of min/max rate pairs. One each for intermediate, premium, and specialty vinyl. The are, currently $9/$18, $10/$20, and $11/$22 respectively. These might change without notice but for the nonce they work.
Substrate, if any, is marked up to suit my own prejudices and then added to the total.
Thus for the previously mentioned 3x12 banner, using a special banner min/max of $6/$18 I'd get ~$246.00 regardless of what it had by way of copy.
I don't sweat the small stuff, like grommets, multiple vinyl colors, etc. It always works out that for every job I make $K-a couple of nickels for extras, I have a job that I make $K+that same couple of nickels due to extreme simplicity. I shoot for the average relying in the immutable principle of return to the mean. It works for me and I spend zero time agonizing over prices.
