Huge Gap between Jobs (Onyx / UCJV330)
jharler
Anyone know why my Mimaki UCJV330-160 is leaving such a huge gap between jobs? I'm using Onyx Thrive 24. The setting on the printer for spacing between jobs is set to zero. In Onyx, the spacing between jobs is also set to zero and the print preview shows no gap between the jobs. I have similar settings for my Epson s80600s and they print fine. This is an incredible waste of material and I'd like fix it.
Smoke_Jaguar
Looks about normal, but I don't use Onyx. Gap between jobs tends to be about the depth of the platen on most Mimakis. Can try combining jobs into 1 big job to reduce it. A pain, but no real easy way around it.
Graphic Extremes
Knows To Little
That looks correct, I have not found a way to shrink that space down. Even with conserve media or group together, does not change the space.
jharler
That's unfortunate. The way our workflow goes, we could easily change that to a 1" gap and be fine. An extra 5" of wasted material between each panel means we're losing multiple feet of material from each roll. Combining multiple panels into one job isn't feasible for our workflow, unfortunately.
Have you played around with just letting Onxy's nesting do it? For example, in the job you show in the picture above, it looks like the same job twice. Can you change the quantity in Onyx to 2 and tell it to only put an 1" between them? I know that's doable in most RIPs but I don't use Onyx.
jharler
I appreciate the suggestion, but yeah, I use multiple copies of the job in Onyx and I get the exact same result. With the job above, Onyx is configured to leave no space between jobs (so the barcodes should be nearly touching). I'm pretty sure it's the Mimaki doing this, as the spacing between jobs works fine with my Epsons.
That makes sense. It seems Onyx handles multiple copies by sending 2 separate jobs in a row rather than as 1 large job so the printer is getting the signal that one job is done and now a new one is coming instead of one continuous job which Mimaki handles by adding the space unfortunately. It's been a complaint since I've worked on them.
Smoke_Jaguar
One semi-workaround is to just not to an auto-cut and back-feed the roll with the arrow keys and set origin with Enter.
jharler
You need to change a parameter on the machine menu , don’t remember now the name , will post a photo tomorrow
Thanks, I appreciate you taking the time.
My Canon Colorado did this until I found the lead and trail settings on the printer
I've been through all the settings and there is a setting for spacing between jobs, but even at zero, it leaves this huge gap. I haven't seen anything like lead or trail in the settings.
I appreciate the idea, but unfortunately this isn't really practical when we have a dozen jobs to print. I don't have the time to babysit and do this with each job. The media waste is less expensive.
Barrett
Hi there! I had the same issue and spend hours trying to fix this.... It is related to the profile you are trying to use... Load another similar profile... The drying time of the print on the platen has something to do with it... When you print, the machine thinks the print has not dried sufficiently and moves exactly the width of the platen forward.... I lost lots of paper on the day... Heavy frustration.... I loaded a "new" profile that had the same name but different slightly.... I had to revert back to the previous profile.... Also check the head hight in the profile settings... Not exactly sure how this works... I wish Canon had propper training on the Colorado... Such an amazing machine ...
Costaricanprinter
image.jpg Sorry for the delay
I have a UJV100 and a UCJV330
And works , you need to set the space between pp to 10mm
That reduce space between jobs
jharler
This is a Mimaki, not a Canon.
Sorry for the delay
Does it have to be exactly 10mm for this to work, because I've tried setting this parameter to a few different values and it doesn't seem to change anything.
Costaricanprinter
10mm is the minimum allowed the machine roll back the material and the separation between jobs is about 2 cm
I print complete rolls no waste
Reactions: 1 users
jharler
I adjusted that value to a little over .4 inches and while it didn't give me a gap of .4 inches, it did about half the gap between panels, so that's saving me about 3-4 inches between jobs. While not perfect, it's certainly better, so thank you for that.
