The Construction font looks like a common sans serifed font like Arial or Franklin the top is only 3 letters. In Coreldraw I would put it on layer 1 then lighten it or put a white cover at 40% over it so I could see it it ok, and on layer 2 Draw the outlines to get a basic shape, Then make the nodes that need to curve into curves and adjust them all until you've made the outlines of those letters. Takes about 15 minutes. Then it is yours! You make it any fill and since it is shapes you can blow it up to 30 feet if you want. Here, I did it! but it wouldn't let me attached the CDR so I made a giant PDF of it.
