Illustrator wont let me stretch
showcase 66
My youngest son was in the office with me and yelled dad catch turned around and he threw a baseball I had at me. It ended up landing on the keyboard and know I cant pick an edge and stretch anything.
Any ideas on how to get it back to working correctly. It is driving me nuts.
SebastienL
White arrow selection tool - second icon from the top on tool palette. "A" on the keyboard.
Really not sur if this is what you mean though...
qmr55
Not sure if there is a setting for this but possibly it was enabled when the keyboard was hit? Try scratching your preferences and starting it over. See if that fixes it.
showcase 66
I can move the objects and it has the square nodes on the corner and middle of each side just wont let me stretch it.
The computer should be back up in a few.
Hopefully it will fix it
J Hill Designs
if that doesnt help:
Up to Illustrator 10, almost all the preference settings were included in the AIPrefs/Adobe Illustrator Prefs file, and almost all issues with corrupted settings could be solved by deleting or moving it; in some rare cases, moving or deleting the folder holding the settings was required.
From Illustrator CS on, the preference settings have been spread over a number of files/subfolders so in many cases deleting the AIPrefs/Adobe Illustrator Prefs file is not enough: the easy solution is to move the whole folder rather than trying to figure out which file(s) may be corrupted; just deleting the folder without moving it first has proved fruitless in some cases.
Therefore, the cure all consists of the following steps:
1. Close Illustrator.
2. Make a search (including hidden files and folders in Windows) and including subfolders for the folder holding the preference files; the name of the folder depends on the Illustrator version, and the position of the folder depends on the OS version. There is one folder for each version and for each user so it is important to find the relevant one.
Up to version 10, the name of the folder is Adobe Illustrator [X],
From version CS on, the name of the folder is Adobe Illustrator [X] Settings.
[X] is the version number; up to 10, it is just a number, and above that the Creative Suite version number, CS, CS2, CS3, CS4, and so on, is used (the corresponding standalone versions still have simple numbers, CS is called 11, CS2 is called 12, CS3 is called 13, and CS4 is called 14, but the version numbers with CS are used in the folder name).
3. Either:
a) Create a subfolder and move all the contents into it; or
b) Move the whole folder to a place where you can find it again, such as the Desktop.
With both you may recover the contents of the folder by moving it back if the issue is not solved and get your preference settings back.
a) requires creation of the subfolder, but it makes recovery easier, especially if you create a shortcut to the preference settings folder, and you can skip the search if/when corruption occurs again.
You may delete the folder/contents subsequently.
4. If you have Windows Vista, restart Windows. If not, continue to 5 without delay.
5. Restart Illustrator, and see whether the issue is solved.
If the issue is solved, and you wish to keep as many of your preference settings as possible, you may move the folder back and repeat 3) - 5) for groups/individual files/subfolders until you have found the corrupted one(s). You may also start by only moving the AIPrefs/Adobe Illustrator Prefs file.
showcase 66
It is working again. not sure what the hell happened. When you would have the curser over the nodes on the corners it wouldn't give you the double arrow to stretch.
Thanks for the advice guys.
HaroldDesign
Don't chase ghosts. It may never happen again. :wink:
Fontgeek
It may have been something simple like having the anchor points/nodes "hidden" which lets you select an object or anchor points without them being shown or "highlighted".
This is handy for working on small or detailed pieces without your view being obstructed by the handles or anchor points. On a Mac you can toggle this feature on/off by using Command-Hm, for the PC side it's Control-H.
If you could see the anchor points then the object may have been "Locked". In later versions of Illustrator you can still see the anchor points when you move the cursor over them, even though they can't be moved. To lock something down you use Command-2 on a Mac, or Control-2 on a PC. To release or unlock them you use Command-Option-2, for the PC I believe it's Control-Alt-2.
If you got a gray matte around the perimeter of your screen then you need to look in the upper left hand corner of your screen, there will be an arrow pointing left, click on it and it should take you back to your normal screen. That gray matte is Illustrator showing you a sub-layer. Clicking on that arrow takes you back to seeing and working on the original layer.
