"I'm getting error code 21.2:10 (Printhead cleaning cartridge error) on my HP Latex printer. What is the most common cause for this?"
Norbertoka955
Hi everyone,
I am getting error code 21.2:10 (Printhead cleaning cartridge error) on my HP Latex printer.
Here are the details of the issue:
  • The error occurs immediately upon startup, even when I try to boot the printer without the cleaning cartridge inserted.
  • The issue is not with the gear on the cleaning cartridge itself, but rather the internal drive mechanism inside the printer (likely the Web Wipe Motor or Spit Roller Motor area).
  • The internal drive mechanism appears to be completely stuck and won't turn, likely due to heavy dried ink buildup. I managed to clean out some of the dried ink, but the mechanism remains jammed.
Could this be a failed Web Wipe Motor, a faulty Service Station drive, or just a mechanical jam in the gear train? What is the best way to safely free up this motor mechanism, or does the assembly need to be fully replaced?
Thanks for your help!
Norbertoka955
A nyárshenger motorja beszorult/beszorult. Ma levettem a fedelet, és a fogaskerekek egyáltalán nem forgathatók. Továbbá a nyárshenger motor szerelvénye laza/billeg."
