Import EPS with Cut lines to Flexi 22
SLShop
We previously worked with Corel, using the Summa plugin, and all our print and cut data are ready in the CDR format. In Corel, the cut paths are stored under the "Kiss-cut" layer. I can export everything as an EPS and open it in Flexi, but I find no way to manually change the paths to a cut path.
Attila Nagy
Easy to select them as they are on separated to they layer already. Then choose -Arrange->Contour Cut->Make Contour Cut. or just Ctrl-Click on the CutContour color at the palette.
