Import PDF files
Drip Dry
In past versions, I could drag and drop PDF files from the desktop into Flexi
With the newest version, I'm forced to use the import function.
Am I missing something ?
Zoogee World
Domed Promotional Product Supplier
Have you tried running the program in Administration mode or whatever it is called, I believe I had a similar issue with Versaworks and drag and dropping eps' when we got the new version for our SG-300.
Medina Signs
Old Member
I've had the same problem over the years and it seems like it's a problem with available ram. I shut a few things down - sometimes a re-boot, and it woks better.
karst41
Technically you should always use the import function. Drag and Drop
is a luxury.
Check for UpDates.
