In need of some answers no hair left to pull.
JLSignsLLC
Flexi 8.6v2 Mutoh 1614, graphtec q64. Having an on going issue with my media being cut in an arc. At the beginning of my cut job the contour is on the money, as it travels further down the media my contour becomes off on the x axis. When it gets to the middle it is off the most. from the middle to the end of the job the cut gets closer to where its supposed to be. Both the beginning and the end of the job are cut perfect. I had an issue before with my cutline off on both X&Y axis. I went into my control panel on the q64 and adjusted both axis. Problem solved. Not sure how to adjust an arc!!!!!!!!!!!!!!!!!!!!
Any help is help. Thanks,Jason
HulkSmash
Make sure your rollers are all clamped down in the back. Typically this happens when like 2/4 rollers are tight, and the others arent. If that isn't the case there's typically a way you can calibrate the cutter.. that worked for us
TammieH
Make sure all of your rollers are clean on both machines. How long of a job are you printing and cutting?
striper14
gotta be calibration of one of your axes (?) If the curves out in the middle but not on the ends ( too big or too small ?) you need some fine adjustment to that axis. Try cutting a large circle from some scrap,say 300mm, & check the size. Only needs to be a mm or 2 out
cheers
HulkSmash
I had this issue using fexi once. The issue was that i was printing outside the allowed print areas, and the cut areas wouldn't stretch to the same areas.. dont remember how we fixed it or what the option was.. dont use flexi anymore.
JLSignsLLC
Its just boggles my mind when you explain what is happening to tech support and there just as lost as i am. Maybe if I pour a bucket water on all my equipment the this catastrophe will disappear!!!!!!!!!!!!!!!!!!!!!!
