Need Help Ink chipping on edges of acrylic
WhiteOak
Wide Format Estimator
We are doing a second surface print on clear acrylic on our Epson V7000. It prints full color reverse with white as the last layer. We are cutting it on our Colex, printed side up, using a down-bit. We are getting a lot of ink chipping along the edges. Is there a better technique for this which will give us a nice clean edge?
Grizzly
It’s all about your print!
Are you using an ink promoter? If not, you need to use a digital acrylic. It’s notoriously hard to get ink to stick well to acrylic unless you’re doing one of those.
  • Agree
Reactions: 1 users
Hello,
I use LUS-150 ink—which is optimized for PMMA—with my Mimaki JFX200. It’s more expensive than the standard ink, but it adheres better.
Do you clean your print surfaces with IPA before printing?
I cut my sheets using a 140W CO2 laser, and the cuts are perfect regardless of the print direction. I’m surprised to hear you’re cutting with a Colex, though. Do they make CO2 lasers?
White Haus
Not a Newbie
Have you tried an up-cut bit? That's all we use on our Summa F. That being said we don't do a ton of direct print then CNC work. Might be worth a quick test to see, I bet up-cut bit will give you less/no chipping.
M.I.Selkirk.Signs
Team Lead - Graphics
Are you applying pre-mask over the print before running it through the router? That little something extra might help to hold everything in place.
bdw99
Is it the white ink that's chipping? Not sure what version of UV flatbed controller you're on but there is a newer setting that allows you to set the white ink quality. I have found that if its at 1 the white ink is kind of chalky and can chip easier whereas if you set it to 3 it's much smoother.. I'm not sure if that would help but just a thought.. We always pre cut our acrylic..
Boudica
Plus 2 for the adhesion promoter. We had some ink chipping once after CNC cutting some acrylic post printing. After we started using the adhesion promoter we haven't had an issue since.
sbergman
We had these same issues (ink chipping) when we printed with our UV Hp FB550 on 1/4" thick acrylic. We tried the ink adhesion promoter (it smells so bad) and foam roll pads on the spoilboard (X-Edge Matrix Mat) but nothing worked very well.
We are now running an HP R1000 with latex ink and don't use ink adhesion promoter and don't use foam pads and we don't have any issues. We cut with a multicam 3000 using X-edges XR2062-CB tool (upsprial) - 500 in/min @ 24K RPM.
