Need Help ink overflow in a UJF3042 mk2
appear
hello everybody,
I've this issue on my plotter, the first day I saw it I did solve it with the function "overflow" under the maintenance menu, but now this function cannot solve it.
The ink overflow is for white.
Is there something I can do or I necessarily have to call the support?
thanks, regards
Smoke_Jaguar
Could be a leaking ink valve causing the subtank to overflow. Located at the back of the bottle station it's p/n M026750 and they're like $25.
OIP.sEAih-SpfyyWoj1Ma9Um5wHaF9
appear
thank you.
This valve works for all colors or there is one for each color? In ujf there are 6 ink bottle, so there are 6 valves inside the plotter? Is it reasonably "easy" to substitute it?
Smoke_Jaguar
One for each bottle/color, all same part number, should be 6 of them (8 on the UJF-3042 MKII EX).
Smoke_Jaguar
Good luck, the fittings they use are pretty dang obscure. Also, probably generally a TERRIBLE idea.
