Ink Pump Motor Pin Connector
schenkco
I've recently bought 4 new ink pump motors for our CET Xpress 1000Q. Please excuse my lack of knowledge around replacing printer parts. The motor came with just two exposed wires and no connector. I'm planning to replace one of the motors but before I do so, I would like some guidance on how to change the connector. Do I just pull out the connector from the other pump and replace it with the exposed wires of the new pump? The new pump is the exact same model and make of the existing one.
Much appreciated for any help!
Django
I know post is old but thought I chime in. You will need new pins to crimp on and the actual molex connector. It would be in your best interest to have new pins and not to reuse old pins.
schenkco
I thought this thread was a lost cause-thanks for your response. I just did a search on molex connectors but there are so many to choose from. Is there a generic one that are used for ink motors? The ink motor I have is a DC 24V/3W. Much appreciated for your help!
Django
Not a generic one. You can take a pump that already has the pins and connector to a local electronics shop and they should be able to help you identify. You can check with digikey, once the sizes are identified.
