Install vinyl in high humidity room
gnubler
Customer wants a door window blacked out in a hot tub room, just black vinyl installed on the inside of the window. Any recommended brands to use? Any tips on doing the install? I was planning on doing it with the door open so I can get the glass totally dry.
Johnny Best
Tex can clear out the room for you to install vinyl.
You will also see that not everything in Texas is big.
Then, he/she did it wrong or used the wrong kinda paint.
The correct way to do it is to remove the door and take it somewhere to use whatever method of choice and do it under correct conditions.
mkmie
Lost Soul
Any reason you can't apply it to the outside of the window? Either way is it a small window? Throw on whatever you have around. If it doesn't work come back with another material but I am sure any black vinyl will do the trick.
Sounds like a 10-minute job to me.
