Introducing WrapCut Fine Filament Edge Cutting Tape
WrapCut
Just as WireTrim Edge Cutting Tape revolutionized the spray-on truck bed liner industry by eliminating the use of a knife for the trimming process of polyurethane coatings, Langeman Manufacturing now introduces WrapCut Fine Filament Edge Cutting Tape as the problem-solving tool and method of trimming for the vehicle wrap industry.
SIMPLE. The learning curve to master this trimming method is short compared to using a knife.
View our demonstration videos. It only takes a few minutes to understand the basics of how WrapCut is used and after that, we know you’ll come up with techniques of your own.
PROFESSIONAL. You and your customers will appreciate the uncompromised finish.
Before Langeman introduced WireTrim to the Truck Liner industry, polyurethane coatings were also being trimmed with a knife causing auto manufacturers to be alarmed by the damage created from cutting into the painted surface with a knife. WrapCut is about to change the course of the Vehicle Wrap industry in the same professional way.
AFFORDABLE. You can’t afford not to adopt this method.
The low cost of WrapCut makes it possible for everyone to switch from using a knife. Priced as low as $0.25 per meter / $0.07 per foot, WrapCut™ eliminates all risk of marking, scoring, or otherwise damaging the paint or glass of an expensive vehicle. Not only that, it allows for less experienced employees to begin applying vehicle wraps.
For more information visit the website www.wrapcut.com
