Question is a roland printer cutter more accurate on smaller jobs (cutting it's own job)
netsol
we sometimes do stickers/decals print cut jobs
as we are getting busier, my question is, will a job of small decals cut more accurately on the machine that printed it?
obviously if the job is 12" x12" stickers a little error will be within margin of error (and easier to compensate for)
but if i am doing a 4" x 6" or smaller, will i have problems, cutting on a different roland or my gerber odyssey ?
SignMeUpGraphics
Super Active Member
Our Graphtec cuts more accurately than our Roland VS540 ever did, so I wouldn't want to assume using the same machine would be more accurate at all times.
  • Agree
Reactions: 1 user
netsol
My assumption of accuracy would be based on the material returning to the origin point after printing.
So we avoid error of reloading. As a tech i know there are alignments that would eliminate scaling errors, between the two machines. These too, would be avoided.
Mr. Signboy
I’ve had 3 different Roland printer/cutters and none of them were ever able to stay accurate on decal jobs over 2-3’. If I had to make 200 decals I would have the break it up into several sections that stay under a couple feet. The size of the decal never mattered much, it was more about the overall size of the job. I could calibrate it a hundred times and it didn’t ever seem to get much better. I would highly recommend cutting decals on a Graphtec or another dedicated cutter, they’re going to be much more accurate. That said, I’ve made thousand of decals on a Roland, it can be done, it’s just slow going and wastes a lot more media.
