Discussion IS Mimaki LF-140 Ink for first gen UJF 6042 /3042 going away soon ?
Tipgypsy
Saw some info on the main Mimaki site about rolling out new ELH & ELS Inks to comply with new Europe guidelines. That will leave the older machine owners in a rough spot for flexible Ink options.
Smoke_Jaguar
Aftermarket inks and chips help a tone when it comes to keeping old machines running. Also, it uses the older chips that can be reset.
Tipgypsy
I used CMYK aftermarket ink but the White is problematic so I use OEM LF-140 . Really thinking about modding a machine to try the newer LUS-150, heads are different don't know if it would run through a Ricoh head.
Smoke_Jaguar
Main thing is setting the temperature for the ink in parameters, the Gen4 heads should handle it just fine. I think LUS-150 is either 45C or 50C.
