Question Is Mimaki UJV 100-160plus worth it comparing it to UCJV330?
LeuritR
Hello guys,
We are looking to buy an uv plotter and since the Mimaki is available we were looking to get ujv 100-160 plus, we will need to get a good clear print and we don't need the cutter on the machine so we don't think we should pay thousands just for a cutting option.
Could somebody tell us the experience with both of this machines or with any of them so you could help us choose better?
Thank you.
FrankW
Do you need white ink?
The UCJV330 is not just an UJV100 with cutter, it has a higher production speed too. And while für an UJV100 you need to decide bevore filling if you want to print white under color or white over color, on an UCJV you can do both driven by the print mode.
Reactions: 1 users
Smoke_Jaguar
The UJV100 is a printer that was just skipped. If they had a UJV330, that would be a great option for those of us who didn't want another slow AF vinyl cutter and the expense thereof. However, I wouldn't hold my breath too long.
LeuritR
Well from what I've seen it's a new printer, it got out of production like 6 months ago and thought maybe somebody bought it and see the experience.
LeuritR
Well how do you mean, why would I want to print white over color, do you have any example that how could i use it like that because under color of course but over color I don't see the point?
Second surface mounts that are viewed through glass/ acrylic.
Smoke_Jaguar
Pullback prints on the UCJV300/330 are great sellers, lets us do clear material with art on both sides and color in middle. Don't think the UJV100 can do that.
Yeah the 100 is considered more of an entry level machine and the 300/330 is their top of the line all the bells and whistles model.
FerSerra
Hello friends, we have a UJV100-160Plus, and it can print double-sided clear material and also print white under color or white over color. Although it is an entry-level equipment, it is ideal for our production. we have some samples on our Instagram freeprint.sf, greetings from Argentina!
LeuritR
Hello,
Did all of your uv printings on your page are made with ujv100-160Plus? I wanted to also ask you how is red on print because usually with ujv100-160 old they say it has a big problem with red color and also from some that we saw that bought the 300 or 330 they have problem with red, so what do you think overall is it worth it?
FerSerra
We already talked on WhatsApp, but to put it on the forum, no, we have not had any problems with the colors in the prints.
LeuritR
Thanks a lot for all the info, I'll be sure to post here after we get it and inform as much as possible for anyone who thinks to buy it.
FrankW
There are several uses. For example on transparent film.
bigjim
I'm definitely not an expert but couldn't you lay down white on the transparent film then print the color on top, leaving it off where you want the white to show? Seems that would give almost an identical look to white on top of the color.
signheremd
We have the UCJV330 and love it. Instant dry, fast, high resolution, great color gamut, can print color white and then color on clear films and vinyl, easy maintenance. Only negatives are that the machine likes to go to sleep often if not running, and it decides to recirculate the ink for 15 minute intervals - sometimes right before you hit go. This machine has really helped increase our productivity.
sad_makaronchi
You can change auto power off time in machine setup. 1 hour is maximum time that accessible on setup
Costaricanprinter
Do you print on 600x1200?
We just got ours installed and that resolution is actually garbage
I have the UVJ-100 too and in comparison 720x900 is actually a pretty decent quality
Side by side I chose UJV-100 quality on mid quality
On 1200x1200 there’s no visible difference
signheremd
Yes, we do use 600x1200 on large signs and 1200x1200 for most of our stuff. But 600x1200 actually comes out really well for us. So maybe needs calibration for that quality.
sad_makaronchi
How high print head? Maybe your print head have height is high or middle, you can lower print head height and do drop position correction, but you need microscope for this
Goatshaver
I had to laugh at this. I've got a 330 and it seems like just before I got and start something it's going to circulate.
