Is there a gloss polycarbonate laminate?
DLab
Hello, I'm looking for a gloss polycarbonate laminate. I can find all kinds of textured, matte options in 5 and 10 mil. I work for a museum and we ordered some signs at one time with a polycarbonate laminate and it came gloss. (I was expecting textured, that's what I used at my old job doing graphics.) Any ideas? Maybe they didn't use a polycarbonate, but it sure seems durable like it.
It will be going on some exhibits and just need something more scratch resistant that a standard laminate. Any other recommendations if this unicorn doesn't exist?
Thanks everyone, this is my first post, but have been coming here to answer questions for years!
VizualVoice
Just my 2 cents, but if you're concerned with scratches and scuffs, a matte finish will hide that a LOT better than anything glossy when it inevitably happens. Glossy it's going to stick out like a sore thumb. If you want extra protection, take a look at the products from Substance vinyl, they have some super thick lams designed for motocross and other high-impact graphics that may be worth using.
Reactions: 1 users
DLab
I will look into the Substance vinyl. We have a lot of matte finish stuff and some gloss. Both seem to be holding up fine. Thank you for the recommendation.
JBurton
Signtologist
Nekoosa used to offer eclypse laminate that was a polycarbonate with adhesive. It's probably best you reach out to them and see what they actually offer currently, but I see velvet poly and gloss polyester both listed under their overlaminates:
DLab
I also found General Formulations MotoMark. It is a monomeric vinyl. Also glossy and scratch resistant, but a little overkill for my application at 12mils.
The thickest polyester I see at Nekoosa is 2 mils, but will be using their 5mil textured polycarbonate laminate, I have a roll on order.
The Substance 8 mil is looking like it might be the right stuff.
Glavin_ID
Polycarbonate film is not scratch resistant in a gloss finish. We use a ton of it for industrial labels and the running joke here is if you look at it wrong it scratches. There are hard coated versions that resist scratching but regular 8010 lexan will show surface scratches very easily (which is why most people stick with matte or velvet). Polyester is a better option for scratch resistance.
DLab
That's good to know. Do you have an opinion on the GF Motomark or Substance products? The sample decal I have from GF seems good, it doesn't tear when scraping my keys on it, but it does leave an indent. I really can't protect against vandalism, but just generally want something a bit more durable. Substance is sending me some samples, so I will report back when I get to try them out.
Glavin_ID
I do not know how a ton about either. We have worked with Substance on side by side graphics once or twice but we don't use it a ton. Our durable labels either get laminated with polyester but it's thin at .001 or second surface print on thicker clear polycarbonate or polyester then adhesive added after printing. The polyester lam we use is a GF product, C1-OL-AP/CLR.
QRcodes
Youre probably right, polycarbonate overlaminate is mostly sold with that velvet texture i think.
So it probably wasn't polycarbonate.
Maybe skip laminate entirely and go second surface. Print reversed on the back of clear acrylic or PC, or face-mount the print to acrylic.
DLab
I need to keep this very low profile. We've used second surface before, but I didn't design this particular exhibit with this in mind. I did do an exhibit where I just mounted acrylic over a vinyl print without even mounting it to the acrylic. It got weird around the mounting screws, but wasn't too bad.
MarkSnelling
You can only really get smooth polycarbonate without adhesive...so you'd have to put a clear perm/perm mounting adhesive on the polycarbonate and then apply to your print.
With that said, I have an ultra dry erase laminate that is inherently scratch resistant with a high gloss. If you are printing solvent/latex/Colorado then it will be great. If you have an older UV printer where the ink is really pronounced, then you'll see that texture through the laminate. It will come in dramatically less expensive than the polycarb + mounting adhesive. a 51"x150' roll is $565.04 plus delivery. You'd get scratch resistance and, if you want, incredible dry erase performance with zero ghosting.
