is there an easier way to add stud locations to FCO letters?
Rocco G
Lately we've been doing a lot more cut-out letters with pins. Yes, i do copy/paste duplicate letters. On small jobs it's not a big deal to manually set the pin locations. On jobs with many letters, it gets tedious. EG, I just quoted a job with about 180 letters, in varying sizes and several fonts. I'm not looking forward to adding all the pin locations manually. Does anyone know of an add-on to CorelDraw or Aspire that will add pin holes? TBH i doubt that there is one but it never hurts to ask. Thanks!
JBurton
Signtologist
Personally, I draw a blue plus sign inside a different colored 1" circle, group them, then drag one around, using the space bar to drop copies. Later I'll do find and replace, find the blue, delete that, then combine all of the 1" circles, then contour those to the desired diameter. I also take a copy, find/replace the 1" holes, delete them, then use those plus signs to make the pattern.
In all of this, it can help to turn off the snap to settings, so you can work further away without snapping to edges.
cwstevens
its all in the details of setup, and it is so far all manual placements, not sure if you are trying to find a way around that. I do similar to JBurton, having set up my file with color coded elements so that you have both the route files to place circles for studs or holes as needed, grouped to a different color cross hair for patterns, and my software (Flexi) allows you to select by attributes (keyboard shortcut D), go to the color fill tab, which selects all of those colored objects, allowing you to separate route from pattern. This is all done by copying just the set up file into a blank page so you aren't dealing with everything in the drawing otherwise, then copying specific setups back into drawing as needed.
Rocco G
Thanks. I was hoping that there was some add-on to Corel. On the next job i will remember to turn off snap-to and keep doing it manually.
JBurton
Signtologist
There probably is, but for what you are doing, ie; spending a few minutes laying out mounting locations per set, if you were to automate it, and for some reason the program doesn't add a hole where it needs one, or skips a whole letter, the fallout would be so much greater than the time saved. Something like mounting points should be at least verified by human, and once an automation takes root, human verification will drop off immediately.
  • Agree
Reactions: 1 user
