Is There An Edge Seal That Is Recommended For Orafol 3751GRA?
ORAFOL Americas
We don't recommend using an edge seal with our films. With proper installation it shouldn't be necessary, but if you are concerned try cutting a thin strip of laminate to put around the edges.
SIGNTIME
there is no point just makes it a pain in the *** to remove... if your worried do a good post heat which you should do anyways or use 3951
player
Actually it is not so much the edges as there are vertical welds running through the whole print ( 1/4"-1/2" x 54") and I was very careful but found some small areas had lifted over the welds.
There are also some very small holes and splits over the welds. I am looking for some type of clearcoat that I can use to repair and seal these breaches.
