Issues with Setting Up the Summa DC4xs Printer on Colored Vinyl
Bonlite
Hello, I need help from the community. I purchased a used Summa DC4xs printer in excellent condition for a specific purpose—printing safety signs. For a month, I have been printing and cutting stickers, but only on white vinyl. Now, I want to print on colored vinyl.
  1. On signal blue vinyl – printing only in white
  2. On signal yellow vinyl – printing only in black
  3. On signal green vinyl – printing only in white
  4. On signal red vinyl – printing in both white and black
I am facing issues with correctly setting up the printer.
The Summa DC4xs manual does not provide clear instructions on this. I followed the guide for the Summa DC5 - Printing on Dark Colored Media. I started with blue vinyl. My vinyl has a non-standard width of 63 cm (24.8 inches), and the printer displays a message that the width has changed. I attached white vinyl on both edges of the blue vinyl. I changed the OptiTrac color to white, and the printer also notifies me that OptiTrac and media calibration need to be performed. However, when I start media calibration, the vinyl shifts, and I can't get it to work properly.
Then, without calibration, I sent a print job. The file included white-only printing, contour cutting, and through-cutting. The printer only performed contour and through-cutting but did not print.
What am I doing wrong?
I would appreciate guidance on the correct setup steps to accomplish this task.
Thank you in advance!
  • Printing on Dark Colored Media.pdf
FrankW
There is a setting for the OptiTrac-Markers for printing them in a color like black with a white surrounding. As far as I remember, the DC4 has another kind of sensors than the DC5. Don´t remember where to set it, but perhaps you will find it in the manuals.
Do you print with Color Control? You need to assign white as a spot color in Color Control.
Bonlite
Thank you for your response and questions.
Yes, I am printing from Color Control. In the photo, you can see the Color Control configuration, where the printer only cut but did not print. I also don’t understand why Color Control displays black, even though there is no black color in the file.
In the photo, you can see the file I am sending for printing and cutting. The blue color on the left was added for better visualization in my example.
Question 2​
For some reason, the printer cuts twice along the same line for Flexi Cut.
In Summa Printer Control 1.13.0.0, there is an option to select OptiTrac Color - White and OptiTrac - AUTOMATIC. As you can see in the photo, I selected white for blue vinyl, but the printer failed to detect the marks.
I would appreciate your help with the settings so I can successfully complete this task.
FrankW
You should set the color space not to monochrome, and set White as a spot color (in the file too). Set OptiTrac to WHITE_BACKGROUND,
Bonlite
Frank, good afternoon. Everything worked out as you said.
Thank you.
I have one more extremely important question:
  1. How can I print white on colored films so that it looks white?The white color when printing on Oracal 751C-508 (signal blue) does not completely cover the blue and looks not white. - see photo #2.
    I also tried printing with a black mask under the white - now the white looks gray - see photo #3. I set the density to 14600 and used double density. I'm worried about tearing the ribbon. Could you please share your opinion?
Thank you in advance.
FrankW
You´re welcome.
About white:
You can set Color Control to print more than one white layer. As far as I remember, you can set this in the "Advanced"-Tab of Color Control. If you post a screendump of this tab, I can show it to you.
Bonlite
You´re welcome.
About white:
Good afternoon Frank. I have attached the bookmark you mentioned.
One more question—I want to print prohibition signs on red film (using white and black ink)- (For visualization, I placed a red background under the print file.) photoVerboten but when I select "Spot Colors Only"(photo Spot color only) mode in Color Control, black is not available. As a result, only white is printed.
FrankW
Not shure. I think it is a setting about "Masking". You have the possibility to set the cassette id for every mask to white.
About the red signs: set black as a spot color in the file.
Bonlite
For white – assign a mask to white so that it is printed twice?
For black – do you mean selecting any spot color for black in the file and then changing its number in Color Control, as shown in the photo?
Bonlite
A question on a different topic. I would like to find an affordable solution for inkjet printing with white ink and a cutting function at the same time (for printing small stickers).
What would you choose for yourself if you had this task?
FrankW
You should talk to a dealer, depends on your priorities. White is a little bit difficult with solvent printers, I would prefer UV. Mimaki has a 800mm printing width Print & Cut-Machine UCJV300-75 for little stickers (107 and 160 available too), they work fine. It looks like that you are from germany? If you are interested, I could set you in contact to one of our sales persons (I work at a Mimaki Dealer in support). Please PM me.
