gut0viski123456
I have a JFX 200-2513 non EX UV flatbed that leaves streaking line marks on the same direction that the head moves, it is present on all prints and on all colors, but it is specially visible on darker tones.
I use a 2mm head gap instead of 1.5mm as default since the materials are not all smooth and flat.
I also use raster link 6 plus version 6.3.
Is that normal? Is there a fix? Anything to mitigate it or check?
Your black is deflecting pretty consistently across the nozzles. Flushing it may fix the issue. I'd also recommend changing the primary filter if you haven't within the last year. It's supposed to be a yearly thing but most people go until there are issues.
