jv33-160 ink error
JmJgraphicd
JMJ Graphic Signs
I am asking for advise on jv33-160 it has ink error on brand new cartridge red flashing light solid green have used 2 new cartridges and same error says the error is almost end I cant clear with new cartridges don't know what to do with it not a lot on internet about this error i would appreciate any advice
caribmike
Retired with a Side Hustle
I have the same machine. Its probably an issue with the cartridge chip. Maybe your ink has expired. I always keep extra "forever" chips on hand just in case I run into a problem like this (and I have). Once, I inadvertently ordered way to much yellow and it expired before I could use it. The back up chips saved the day. I buy my ink from STS Inks in Florida and they sell chips too. Also, I have had to replace the chip reader in the Solvent Cleaner bay a year or so ago. It was easy.
The ink end sensor is probably broken. There's a little lever in the cartridge holder that gets pushed by a little flag on the cartridge when the cartridge is empty. If that lever gets broken, it will flag the cartridge as near empty for every cartridge you install. It writes it back to the chip so it permanently flags that cartridge. Take a look in the cartridge holder and compare it with one that is working. You should be able to see if it's broken.
