Jv33 Bulk ink
GTSTech_1
You will have to wait on a true "Bulk" solution from Triangle for the JV-33. You can currently use Triangle Carts for the JV-33. They are still refining the chip charger system.
Modern Ink Signs
I've used the Triangle Bulk ink from the day that I bought my machine...........about 3 1/2 years ago.
I did hear that the warranty is void if you run the Triangle bulk ink. That was not the case when I purchased mine. However, I did hear last week that Triangle has picked up the warranty in the parts that their ink touches. Don't know if this is true but is what I heard.
Also..............You will have to make your own profiles. I have not seen/heard/found any profiles for this ink set.
I get good color from my inks.
praveen
Thank you all...
I have just received the easy Fill Pro ( JV33) and JVV inks with chips...
have to try on my JV 33 its only 1 month old ..
