JV33 Heat settings
hbb2008
Does anyone have valuable information about heat settings? I am not printing on vinyl but rather thin 65g 70g decor paper for the laminate industry. With dark or high saturated colors I get waves in the paper that create blurry parts of my print. I've tried to adjust my heaters in all different directions and some times i still have no luck with keeping the paper flat on the printing zone. I can manage lighter colors much better than darker colors.
what is important about the pre heat/print and post heat ?
Aqueous ink
printing mostly 8-pass, bidirectional but depending on the print I change to 16-pass or unidirectional. I prefer 8-pass, bidirectional because it is much faster.
thank you for any information
iPrintStuff
Prints stuff
The problem is likely saturation. You’re probably laying down too much ink on such a thin paper.
That’ll be why the lighter colours are easier, less ink.
depending on how you’re running the printer, you probably have to have a look at the ink limits in the profile.
hbb2008
Thanks, that is exactly when the problems arise-with dark or high saturated colors. With more testing this past few weeks, I have found a good result with many colors using 30/40/38 or something close to that. But I have more tests to do for higher Saturated colors. Always open to learn more
