JV33, HS ink and SS21 ink
DigitalBBQ
Has anyone using Mimaki HS ink running inside the JV33 for the machine sold in the U.S.A market?
Will JV33 physical components such as ink lines, plumbing, dampers, etc can handle HS inks :help
captan77
HS inks will work properly on this machine, take in mind that adhesive qualities of HS are better than SS21. And drying time also better. So you could avoid banding that can appear using SS21.
KurlyT7467
I know this thread is old, but if I am using SS21 ink on my JV33 and want to switch to HS can I just start replacing SS21 cartridges with HS ones as they go out? Or do I need to completely switch out all of them, and bleed/clean all of the lines?
