so 2 problems happening, not sure if theyre related
sometimes when i do a test draw there are major parts missing, sometimes half to a whole color head, usually magenta. also sometimes the magenta bleeds with the other colors
so i do a cleaning or ink fill. then sometimes when i do this i get a error 9 hdc problem, but the head numbers varies. i reboot and repeat the process until i get a successful test draw
this problem has exsisted for a while, but it has increased A LOT since a tech came in and adjusted the heads
any idea whats going on? the hdc error id guess is a data cable, but would that then cause the dropped heads/colors?
