Need Help L25500 need help
tomcnc
Hi I am new here. I have a l25500 put in a new cartridge and belt both are original hp and encoder strip is a China one.
Ok I boot printer up it loading the cartridge move to right then when it goes to the lefted it gives me error 86:01. But when I do the scan axis test it give me this error.
Trying my best to get this printer up and running for now I have less then 600 invested in it. Can anybody help me with this printer is for my daughter to learn for now
Thanks Tom
balstestrat
Problem Solver
Well it sounds like your chinese encoder strip is no good. That's what it says right?
Get an original and I bet that goes away.
jimboeejit
cant help but think of the belt being put in correct place...as the jointer on it may be hitting the motors or something...
Nehal
Thanks Tom
Find
Thanks Tom
Hi,
Check this. You will solve
https://signs101.com/threads/l25500...-process-of-the-carriage.149879/#post-1470662
Nehal
Thanks Tom
Check this and solve.
https://signs101.com/threads/l25500-trouble-after-belt-replacement.153328/#post-1470658
tomcnc
Ok
Did PCA test it pass
Line sensor pass
Paper jam test pass
Scan axis fail again
I going try keep adjusting the rubber parts to see it one pass first one fail still.
I going try get a new encoder strip try for the original one but dont know if I should put more money into it.i still will need to get new printheads and ink.
Nehal
Ok
Line sensor pass
Paper jam test pass
Make sure Encoder strip is not damage & it must be original.
Re calibrate scan axis.
After replacing belt you must re calibrate scan axis.
Printer don't know where to start & where to stop.
It will do left bump & right bump all those things in calibration.
Read manual how to do.
Must must pass scan axis & calibrate again.
Use good rubber piece.Solid as in my photo.
tomcnc
ok i just notice when i do scan axis test it says its going to move cartridge to the middle but it dont it move just alittle from the left side
how do i re calibrate scan axis i am in the service menu but i dont see it at all
Nehal
You can not do from service menu.
Read my above post & manual properly.Everything is there. Just follow proper steps.
