Anyone have any suggestions for laminating 6MM ACM panels. We have a Guardian 65'' Heat assist laminator and are having issues laminating larger 6mm panels. We typically get a narrow strip of bubbles down the middle of the material where the laminate is not making good contact. Weve tried different pressures and still having the same issues.
When you have problems down the middle, that is a
sign your pressure is too high. The pressure is applied on the sides of the rollers...think like a rolling pin in your kitchen....and the harder you press on the sides the more the roll deflects or beds up in the middle.
The Guardian is an entry level laminator that wont't provide some of the pressure control that better machines have.
It takes barely any pressure at all to get the adhesive to stick...so get the rollers touching with the least amount of pressure as you can and you should see some improved performances. Feel free to call to talk it through if you'd like.
